TwinTurbo.NET: Nissan 300ZX forum - Re: Is the Engine/Ecu wiring Harness a TT?..
ZVella32
on March 18, 2019 at 12:33 PM
posted by Cjw3
on March 18, 2019 at 05:58 AM
I did the swap. I know that the wiring harness I used for the engine is for a twin turbo. Is the white wire related to the wiring harness for the engine or the wiring harness for the fuses ?
Smog Referee : fan needs to be controlled by the ECU
ZVella32
02:24:10 03/17/19
What ECU do you have in the Car.. NA or TT
Cjw3
11:51:25 03/17/19
Here is my Search
Cjw3
12:15:51 03/17/19
Re: Here is my Search
ZVella32
15:53:48 03/17/19
Re: Re: Here is my Search
ZVella32
15:59:56 03/17/19
What is a spal Kit.. and can you post a Wiring Diag? (n/m)
Cjw3
16:37:07 03/17/19
Re: What is a spal Kit.. and can you post a Wiring Diag?
ZVella32
19:03:36 03/17/19
Re: Re: What is a spal Kit.. and can you post a Wiring Diag?
ZVella32
19:05:46 03/17/19
Here is the ECU Wiring Diag
Cjw3
21:37:27 03/17/19
Re: Here is the ECU Wiring Diag
ZVella32
00:37:15 03/18/19
Cjw3
05:58:08 03/18/19
Re: Is the Engine/Ecu wiring Harness a TT?.. -
ZVella32
12:33:58 03/18/19
It will come from the ECU..
Cjw3
13:42:51 03/18/19
Re: It will come from the ECU..
ZVella32
15:45:28 03/18/19
Re: Re: It will come from the ECU..
ZVella32
19:38:41 03/20/19
Chasing the Wiring on the Fans..
Cjw3
20:21:58 03/20/19
Re: Chasing the Wiring on the Fans..
ZVella32
23:01:10 03/20/19
Your Engine Loom is a TT, the White Wire is there..
Cjw3
06:56:10 03/21/19
Re: Your Engine Loom is a TT, the White Wire is there..
ZVella32
19:20:14 03/25/19
ZVella32
21:39:40 03/25/19
Re: What ECU do you have in the Car.. NA or TT
ZVella32
15:42:23 03/17/19
